#37 |
![]() Drives: Yaris TR 1.33CVT Join Date: Jan 2012
Also ordered from CTScott and got the parts in UK very quickly and no customs issues (despite USPS tracking saying the package is still in USA!)
I notice my steering wheel assembly is slightly different from Richard_RSP's (but thank you for the pictures that helped a lot in knowing what I was aiming for. I have the steering wheel audio and also the bluetooth telephone control on my UK Spec 2012, 1.33 Yaris TR Auto (not sure which bit of that means I have the different clips though!) Also, pin 1 & 2 of the 10-pin connector are already occupied so I put the cruise in the spare 4-pin socket next to it. Edit- It works! Last edited by stuart_f; 07-10-2012 at 10:21 AM. |
#38 |
Excellent! I am glad to see that the installation went well.
#39 |
![]() Drives: Yaris Join Date: Mar 2012
hi...i'm just reading all posts, but i have a question..
are you always talking about 1.33 VVTI, right? is it possible to have cruise control in a 1.4 D4D 2012 yaris ?? |
#40 |
Correct - According the the wiring diagrams for the European Yaris, only the Yaris with the 1NR-FE (1.33L) support OEM cruise control. Ones with the D4D would need an aftermarket cruise control solution.
#41 |
Thank u very much....
Its a pity....:( |
#42 |
no show, no go :(
hey there scott, got anymore stalks left? i'd love to pick one up from ya...
#43 |
I sure do. I'll PM you the details.
#44 |
![]() Drives: '12 3dr Yaris L Join Date: Sep 2007
I'm working on installing the 2-button cruise control on my 2012 L automatic. I am having trouble identifying the correct wires to connect to. On the 06-11 D3 plug there is a black wire, and then a blue and brown wire if you have the correct wiring to the computer. Here's a pic I took from under my steering column. If I were to assume, I'd say it's still the brown and blue wires on the plug next to the yellow one. But I'd rather double check with you guys who know.
Link to the type of cruise control mod I'm using. http://www.yarisworld.com/forums/showthread.php?t=17158 |
#45 | |
#46 |
Awesome, thank you very much. I never would have guessed it to be the black plug.
#47 |
Well, I tried to hook this up with no result. I'm partially color blind so maybe I could have the wrong wires. Is there a diagram of the black plugs pins somewhere? Is there a black wire, or a dark brown?
#48 | |
#49 |
Thanks for the quick response, and expert electrical knowledge. I used a micro pot instead of resistors. That shouldn't be a problem should it?
#50 |
The problem with potentiometers is that depending on the construction they can drift. Also, depending on the range of the pot, the under 1K area of the pot can be very small, making it difficult to lock in the correct values.
#51 |
Just wanted to let everyone know I got it working and it's great. I probably ran into every problem that one might run into, but with quick help from CTScott I was put back on the right track. Thanks again Scott, and the forum as a whole.
#52 |
![]() Drives: yaris Join Date: Nov 2012
Got the cruise stalk in my 2012 3dr., but does anyone know where there is a tutorial to get at the clutch switch?
#53 | |
#54 |
![]() Drives: 2012 1.3 Xr CVT Join Date: Dec 2012
Does anyone know how to access the other 2 clips if you have shift paddles ?
( 2012 1.3 Xr CVT 5Dr ) I found the access hole on the bottom, but none on the sides some images for clarity : The driver view ![]() The access hole on the bottom: ![]() Left paddle ( gear down): ![]() Right paddle ( gear up ) with the Cruise control cover thing removed
| Tags |
| cruise control. 2012 |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
