![]() ![]() Drives: NCP91 Join Date: Jul 2012
All Toyota automobiles use lifetime fuel filters. That means, by design, it will outlast your car. However, filter media become clogged prematurely from contamination through the filler, either by dirty refueling equipment or simply dirty fuel (like from a jerry can that has been sitting in your garage).
You should not change the filter unless you or a technician have diagnosed unequivocally that the fuel pump is suffering from poor output. However, that is no reason to ignore regular fuel system services... and I'm not referring to that snake oil garbage you pour into your fuel tank. A genuine fuel service involves either feeding a pressurised fuel-detergent mixture directly into the fuel rail and running the car from it without the fuel pump, or removing every injector for a reconditioning. |
#2 | |
![]() Drives: Red 2008 Yaris S 3dr liftback Join Date: Jul 2012
Cheers :) |
| low gas mileage? | yrsdrgn | General Yaris / Vitz Discussion | 30 | 01-17-2019 03:26 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| damaging or no--cabin air filter | roxy84 | DIY / Maintenance / Service | 3 | 06-29-2007 01:17 PM |
| Increased MPG or HP anyone???? | slvryaris | Performance Modifications | 55 | 05-27-2007 10:49 AM |
| fuel filter | ias205 | General Yaris / Vitz Discussion | 15 | 05-14-2007 11:02 AM |
