#2053 |
Roadrunner Jr.
![]() I hate drilling into metal...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 07-09-2012 at 10:32 PM. |
#2054 |
Me too! I'm going to confirm that in a few minutes!
D.
. CLA 250, 4MATIC |
#2055 |
I did it! I did it! Video1:*It was so easy that I took my phone for a video! ![]() Video 2: Without holding my cell phone for video I could probably have done it in less than half of the time.. ![]() D.
. CLA 250, 4MATIC Last edited by derickveliz2; 07-10-2012 at 01:27 AM. |
#2056 |
OK, this was so EASY, just like a hot knife on butter! best $15 bucks spent.
Now I have left tweeter as far forward and far to the left I possible can! I gain 5 inches and that's a lot! the distance from my left ear to tweeter now is 48" it used to be 43". Stage is wider and deeper already! Probably 5 inches sound meaningless, but you should hear the difference that it makes. Picture 1: the a-pillar after cutting the metal ![]() Picture 2: Tweeter in place! NICE! I'm happy. ![]() D.
. CLA 250, 4MATIC |
#2057 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
What about the aiming? Looks like its down at the dash....
#2058 |
Roadrunner Jr.
The aiming axis at that point will only have a minor effect. The gain Derick has from physical location is going to override the angle for the most part. What I'm going to be interested to see is how the mounting is integrated with the a pillar.
I see that mount is deep...really deep in there. What say you Derick? This may be a good experiment for horn loading...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#2059 |
Roadrunner Jr.
Sand down those edges on that metal, run that wire...are you going to surround the mounting hole with some deadening to reduce resonances? How's the tweeter going to be mounted?
#2060 | ||
Yeah me too! I'm thinking about cutting a big section (hole) in the lower part of the a-pillar and build up a big open horn shape from the tweeter's base to the opening of the a-pillar, I'm not sure how to accomplish that, but I'll dig into it. D. Quote:
Yes will deaden the area, I will use a thin sheet of wood/balsa wood or even MLV as baffle into the metal. D. .
. CLA 250, 4MATIC |
#2061 |
Roadrunner Jr.
Baffling into the metal...I wish I could be out there with you to help. I think between the two of us we could make this happen REALLY quickly.
*sigh* Using some substrate you can drill into using the L1v2's mounting holes. I'm thinking even a 1/4" pan head would be fine and not kick too far into the metal depending on the thickness of the substrate. I'd say make a couple rings out of balsa that are juuuuusssst slightly larger than the outer diameter of the tweeter and then reverse the technique we've used to make the original pillars. Build in instead of out. Thoughts?
#2062 | |
D.
. CLA 250, 4MATIC |
#2063 |
Kind of a speaker mounted in a funnel. Interesting.....Hey, what about using a funnel! lol
#2064 |
By angleing the cut on the material you could still aim it a bit if needed. If nothing else it would be a cheap way to experiment.
#2065 |
Would it have a megaphone effect though if not treated or coated....
#2066 |
Hilser Funnel in process... kind of!
pictures of the cut out section soon... ![]() Hilser Funnel D. .
. CLA 250, 4MATIC |
#2067 |
Area to but removed...
![]() ![]() I'm sorry for the quality of the pictures, I used my cellphone ![]() D. .
. CLA 250, 4MATIC |
#2068 |
Just for FUN...
Painted calipers the other day! ![]() D.
. CLA 250, 4MATIC |
#2069 |
Roadrunner Jr.
@ sick...
I'm not so sure that we'll have much of an effect that far off axis. @ Derick... Go to Toyotapartszone and get another pair of a-pillars. It's a just in case thing. I'm off to do my Army drill thing for the next two weeks and that pillar thing is one of the first things I need to do when I get back...seeing where my tweeters are now.
#2070 |
I saw a picture showing your tweeters in the sail panels! I was going to go that way too.
But now I can't wait for some extra time and cut the right side and move right tweeter there, the stage is impressive to me, and sweets my taste for Front Stage better than before. Good luck in the next 2 weeks! Will be hovering around here! D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
