Old 07-16-2012, 10:28 AM   #1
bronsin
bronsin's Avatar
DOT 3 and DOT4 are required to be compatable with each other so I see no problem. If it was me I would remove a much fluid from the resavoir as possible before adding the DOT 4. Then bleed most of it out at each bleeder one at a time and refill so basically you replace all the stuff in there with DOT 4.
Brake fluid info... 06vitzRS DIY / Maintenance / Service 5 12-26-2008 12:05 AM
