play every day
One of the air bags losing its activation pressure could make the light stay on. I'll guess that they have low air pressure sensors similar to the valve stems on the wheels.
I don't know if you intended this as a bit of humor, but this could not be more incorrect as to how air bags function.
play every day
I'm glad to amuse you CT... but even more humorous, I was serious.
![]() Air+ bag = a bag full of air. What activates airbags? |
They are basically little bombs. There is an explosive charge in the squib that is electrically detonated to rapidly fill the bag (with hot, stinky gas, as opposed to air). The SRS system makes sure that they are ready to fire at all times, by running a low voltage through the squib and looking for the voltage drop across it. That allows the system to detect that the squib circuit is open (broken wire) or shorted.
play every day
Wow... stinkbombs. Thanks so much for the information CT, I understand now. I had just guessed that they were powered by little CO2 cartridges.
| Tags |
| airbag |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 01:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 02:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 09:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 04:41 AM |
