Old 07-27-2012, 09:16 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I wondered about just cutting a ring out of the existing springs to achieve the drop.
it won't help the bounciness. the spring rate won't change. if you want it stiffer, you need stiffer springs (with a higher spring rate). mine are progressive meaning the more they are compressed, the stiffer they are. gives a soft feel at first but then stiff in corners (or speed bumps unfortunately)
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Tein S-tech Springs with Stock shocks combination. daddz07 California 11 08-21-2010 01:49 PM
Tein S-tech Springs with Stock shocks combination. daddz07 Performance Modifications 1 08-09-2010 03:45 PM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 08:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
