Old 07-30-2012, 12:04 AM   #1
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Manifold-back i can sell you a tubing kit right now that would need to be final fitted and hangers welded to it, etc. However the manifold flange is an odd very spaces out bolt pattern...i made my flange out of 2-flanges for my exhaust.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 07-30-2012, 02:11 AM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It is really wide...
I think it's so that the bolts with springs around them will have enough room to clear the donut gasket and socket.
Old 07-30-2012, 11:17 AM   #3
malibuguy
Obsessed with 1.5L
well 1st gen 1nz had a narrower pattern that i used a regular exhaust flange with minor modification. same spring bolt set up.
-96 Tercel 4dr
Micro Image center exhaust... tooter Performance Modifications 64 10-14-2012 11:07 PM
