Old 07-30-2012, 07:28 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
My view...............
Friend commented recently on how much he liked how I have setup my"stuff" in my car. Thought I would share it.
This is my view as I drive, GPS (Hardwired) and UltraGuage in glove box behind steering wheel. Wires come out the front of the glove box and chase down the steering column, lid closes, np.
Radar Detector mounted on and below rear view mirror (Hardwired). I tucked the RD wire into the headliner only I didn't remove the A pillar air bag cover, the more I read about those clips holding the cover in place the less interested I was in messing with them.
There is a "rubber" trim piece that is between the air bag cover and rest of the A pillar that runs all the way down the inside of the forward door jamb. Pulled that out a little bit at a time and chased the RD wire all the way down to the fuse box.
GPS and RD are both on Add-A-Fuses 2 or 3 amps ea.
*Hat tip to shaggyone at planet-9.com for the radar detector mount idea.
http://www.planet-9.com/cayman-boxst...rt-9500ix.html
cheers
BTW- My view is much clearer than this pic appears to be..................
NEexpat is offline   Reply With Quote
Old 07-30-2012, 07:50 PM   #2
ChitownY@Ris
ChitownY@Ris's Avatar
Drives: '07 Yaris Sedan
Similar gps setup. Liking it for sure. No radar detector though.
ChitownY@Ris is offline   Reply With Quote
Old 07-18-2013, 05:24 PM   #3
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I realize this is an old thread, but I got my first-ever GPS today and I'm wondering how that is attached.....two-sided sticky tape?
DebbyM46227 is offline   Reply With Quote
Old 07-19-2013, 03:09 AM   #4
nookandcrannycar
Congrats re your purchase. I don't know what the OP and others use, but I swear by what are now called Scotch All Weather Fastners (they used to be called 3M Dual Lock Fastners -- same product). package of 4 1"x3" Clear strips (2 sets). I used to get them at Radio Shack, but I don't see them at RadioShack.com. Target has them. Not available online, but in the stores. Their site shows that stores near me have them in stock, so it seems to be a popular item. The 'application example' on the front of the new packaging (the lone example) is an aftermarket GPS monitor mounted on a car dash. They don't lose their adhesive in SE Texas heat. I've been using them for over 10 years and I can't remember any of the strips ever failing.
Old 07-30-2012, 08:02 PM   #5
NEexpat
NICE!
And of course, you have the 5 speed (grinding my teeth )
Old 07-30-2012, 08:05 PM   #6
ChitownY@Ris
Auto
Old 07-30-2012, 08:13 PM   #7
NEexpat
No kidding, I thought domestic yari that came with a Tach were 5 speeds, maybe that was the LB's
ok, not grinding
Old 07-31-2012, 07:13 AM   #8
DevilGirl
Drives: 09 3dr LB MT
ok, not grinding
I have a LB manual. My gauge is the same as the OP's. The tachs came on the autos, not the manuals. Go figure...
Old 07-31-2012, 11:25 AM   #9
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
My manual transmission base model has a tach, but its 3rd gen. Maybe the 2nd gen base models didn't.
Old 08-01-2012, 06:51 AM   #10
DevilGirl
Possibly. But mine isn't a base model.
Old 08-04-2012, 01:19 PM   #11
DebbyM46227
I have a base 2010 manual LB. I have a tach.
Old 07-31-2012, 12:11 AM   #12
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
i dont like the idea with the cover up though, neat.
caineroad is offline   Reply With Quote
Old 07-31-2012, 12:34 AM   #13
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
that is a good radar mount idea. i always had that crappy flimsy holder and rested it on top of the mirror. thanks for posting.
Club SHIFT
Old 07-31-2012, 01:16 PM   #14
ChitownY@Ris
I gather when imported from Japan, the yaris center cluster was left as is, & they simply just swapped sides for the steering wheel.
Old 07-31-2012, 01:33 PM   #15
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
My 2008 has no tach (stich shift). I added one though.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 08-01-2012, 08:31 AM   #16
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
I think it's a sedan vs LB thing, not a manual vs auto. Sedan's have tachs.
goliath1812 is offline   Reply With Quote
Old 08-01-2012, 12:39 PM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
2010+ have tachs, here's my car setup. only a scangauge mounted just behind wheel. I use the radio screen for the gps when mounted with my iphone.
[IMG][/IMG]
Old 08-01-2012, 03:02 PM   #18
ChitownY@Ris
Me likes that engine start button^^
Does that work with just a fob in the pocket, a la Prius?
Temp guage and compass in Rear view mirror Chaad32 Cosmetic Modifications (Exterior/Interior) 10 10-30-2020 07:47 PM
Heated Side View Mirrors goku87 DIY / Maintenance / Service 27 01-26-2016 05:23 AM
Rectangle Rear View dlinkwit27 Cosmetic Modifications (Exterior/Interior) 14 03-29-2010 11:49 PM
The screws underneat the side view mirrors... Sodium Duck Cosmetic Modifications (Exterior/Interior) 16 03-25-2009 08:04 AM
Reposition rear view mirror? atebit Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 07:56 PM
