Old 08-01-2012, 07:45 AM   #1
bronsin
bronsin's Avatar
If you leave the dial on recirc in my experience you will crud up the system so it smells like old socks if you run the AC very much. Which needs to be on recirc if its really hot in summer.
So my drill is run it on fresh every day for a few minutes to keep my car smelling sweetly.
If that thing didnt toggle back and forth it would be trouble!
Old 08-24-2012, 11:16 PM   #2
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
Good plan. You don't want to run recirc too very long in cold weather either unless you like steamy windows! Hot days I run recirc with the AC to get the cabin cold fast then go to fresh.( unless there is some stinky diesel truck in front of me! LOL)
Tardis is offline   Reply With Quote
Old 09-11-2012, 11:37 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Mine did this but broke something down where it pivots. Dumbass shop put my dials on in upside down order and stressed the cables. They even had the audacity to tell me I was WRONG about the order of my dials! It broke a few months later when I moved far away, and that was when I discovered the jerk had shaved the clips off the knobs to make them fit (then glued them back in when I showed him a pic of a new on the lot yaris knob location.) I now just remove the glove box and flip it manually a couple times a year, recirculate for summer, fresh air for winter. Totally sucks but I'm not tearing my dash apart to fix it. If I ever did take the dash out it's getting fixed then.
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was service related. I've moved it to the proper sections
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
