Old 08-07-2012, 08:39 PM   #1
Zee518
Drives: 2008 Liftback White
It could also just be unplugged (if someone did some front end work on the car at some point). If you shine a flashlight through the grill you should be able to see the single wire connected to it (the other connection is the bolt that mounts it).
I think you nailed it - I see a green wire clip thats just hanging from the grill...this might be connected to the horn.
Zee518 is offline   Reply With Quote
Old 08-07-2012, 08:56 PM   #2
That's the horn wire. If you look for the thread on changing the headlight bulbs, it shows the easy method of freeing the top of the bumper, which will give you enough space to get your hand in and reconnect the wire.
Old 08-07-2012, 09:27 PM   #3
Zee518
I found this thread:
http://www.yarisworld.com/forums/sho...7&postcount=12
Thanks for your quick reply and help!
- Zee
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
where is my horn located? 2007 3 door Suey 1958 General Yaris / Vitz Discussion 6 11-27-2011 09:57 AM
My horn quit - not the fuse. m3ga_band_g33k DIY / Maintenance / Service 2 12-07-2009 07:11 PM
Help! Horn just stopped working. steveh74 General Yaris / Vitz Discussion 14 09-17-2009 10:23 AM
Toyota Premium Horn Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 22 02-18-2009 11:28 PM
