Old 08-08-2012, 11:18 AM   #3
Ot_tO
Drives: Look Signature... ;-)
Smile
You mean with *pulse width modulation* (PWM)?
Which countries have this dimmed high beam as DRL?
(Which countries have dimmed low beam as DRL? At which %?)
I read, the bulb should run at least with 76 % of max brightness.
If not, it will reduce the life of the bulb, because it need certain amount of heat for the regeneration.
This could be correct?
How are the experiences of the owner of such cars with dimmed low/high beam as DRL?
You need every few months new bulbs?
Thanks.
Best regards!
YARIS II (XP9F) Facelift (2009-2011) 3dr Executive 1.33 (74kW/101PS/99hp) 6gear-MultiMode Jan/2010 (german version)
Ot_tO is offline   Reply With Quote
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
High Beam Issues urbanmindz In Car Entertainment + Electronics (audio / video / alarm) 0 03-19-2009 09:22 PM
High Beam Mod stran DIY / Maintenance / Service 1 11-13-2008 11:06 AM
