Old 08-21-2012, 03:07 AM   #1
joshthorsc
Drives: 2012 Yaris SE 5spd
So far I hate the single windshield wiper and the door panels and can get scruffed so easily.
2013 Tundra CM Rock Warrior
1991 MR2 Turbo
2012 Yaris SE 5spd...Daily Driver
joshthorsc is offline   Reply With Quote
Old 08-21-2012, 08:03 AM   #2
matti
Drives: 2017 Yaris L (5sp manual)
I recently posted a question in regard to the scuffing of the door panel plastic. Someone recommended Turtle Wax F21 protectant as a way to protect from the scuffs. I put it on this weekend and it really helped a lot. It was about $5 at my local auto supply store.
On my 2012 2-door, every time I shut the driver's side door, I think the glass slides down just a bit and I can hear it rattle. That bugs me a bit.
FWIW, I LOVE the design of the tail lights.
matti is offline   Reply With Quote
Old 08-21-2012, 08:16 AM   #3
muffin_top
Drives: 2012 Yaris SE 5MT
The door shouldn't make any noises when closed, take it in and have the regulator bolts checked.
muffin_top is offline   Reply With Quote
Old 08-21-2012, 08:49 AM   #4
matti
I have hand-crank windows: does that make a difference? When I shut the door, I can hear the glass rattling slightly. After shutting the door, I can see that the hand crank has rotated slightly, allowing the glass to slide down just a bit.
Old 11-21-2012, 12:55 PM   #5
matti
Hi there. Just wanted to give a quick update on my driver's side window (hand crank) rattle/movement in the 2012 Yaris L. I had it in for the 5k service today and they checked it out. They said they couldn't really see what was wrong, but they did order a new window regulator, which I'll get installed in about two weeks. I appreciate my dealer's good service so far.
Old 01-15-2013, 04:13 PM   #6
Frank Necrosis
Drives: 2012 Yaris L MT
The interior panels of my L are rough, very rough. I haven't scratched them yet, but they do a good job of removing the outer layers of any skin that rubs against it. The result is smears of dead skin cells all over the door. It is kind of gross when you really think about it. Windex wipes off the cells and leaves no trace.
Frank Necrosis is offline   Reply With Quote
Old 01-16-2013, 10:12 PM   #7
matti
I also found that the interior panels on the 2012 Yaris tended to mark VERY easily. Thanks to a tip from this website, I put on one application of Turtle Was F21, which helped immensely.
http://www.yarisworld.com/forums/showthread.php?t=40989
Old 11-29-2012, 11:29 AM   #8
nookandcrannycar
Some 2012 owners have posted that they feel the single blade windshield wiper on the 2012 doesn't do a good enough (safe enough?) job of maintaining visibility during a hard rain. Have you found that to be the case?
2012 Toyota Yaris alarm tonyc1234 DIY / Maintenance / Service 0 05-04-2012 03:29 AM
Has anyone put a rear antiswaybar on a 2012 Yaris? carolinablue Third Gen Yaris General Discussion 16 04-26-2012 08:41 PM
2012 Yaris Accessory Catalog (UK) CTScott Third Gen Yaris General Discussion 13 02-06-2012 01:36 AM
