Old 08-22-2012, 06:20 PM   #1
MadMax
MadMax's Avatar
I don't think it's possible, this is all the manual has to say on setting the clock...
The digital clock indicates the time.
To adjust the clock, put the key in the “ON” position.
With tachometer—
Pushing the reset knob flashes the indicator for the hour and you can adjust the hour.
Press the reset knob until the desired hour will appear.
After 5 or more seconds pass without operating, the indicator for the minute flashes. Then you can adjust the minute.
Press the reset knob until the desired minute will appear.
After 5 or more seconds passes without operating, the indicator will return to the normal display.
If the electrical power source has been disconnected from the clock, the time display will automatically be set to 1:00 (one o’clock).
Without tachometer—
Pushing the reset knob flashes the indicator for the minute and you can adjust the minute.
After 5 or more seconds pass without operating, the indicator for the hour flashes.
Then you can adjust the hour.
GI: "YarGauge" replacement clock module (Digital Tach, etc.) CTScott Items for Sale by private party 756 03-21-2013 08:22 PM
05 Echo changing time on clock jambo101 DIY / Maintenance / Service 3 11-12-2011 04:34 AM
PIONEER DEH-3950MP husaynkhan In Car Entertainment + Electronics (audio / video / alarm) 12 05-20-2010 01:01 AM
Setting the clock after DST change ToddR DIY / Maintenance / Service 10 03-09-2009 11:33 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
