Old 08-23-2012, 02:37 PM   #1
cybrjoe
Drives: Yaris 07
i try to reset the srs ecu but i cant. That's, what i did: short the 2 pins, srs light began give me code, open the short 3 sec, short 3 sec, open 3 sec, short 3 sec, open 3 sec and short. After that, the light gave me again the code 14. Why ?????. Is that a good procedure for yaris 2007??
cybrjoe is offline   Reply With Quote
Old 08-23-2012, 02:42 PM   #2
The procedure is good, so if it won't reset, chances are that the sensor is bad. To verify, you can swap the right and left (as they are identical parts) and the code should change.
Tags
airbag
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 01:35 PM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 09:20 AM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
