![]() Drives: 2008 yaris rs Join Date: Mar 2011
Ok what i do its:
1-cut the blue wire from drl module 2-run a wire from the blue wire (drl module side) 3-tap in (didn't cut) the pink wire (connector headlight switch) 4-disconnect both side hi-light bulb 12v wire.....why should have needs to cut the wire who run +12v, if we needs constant +12v ?? What we gon do, Run the wire directly on the battery !??? I've doing that last time, except with the numb 4, and its work but the hi-light blinking as hell when i drop off the hand brake loll! What can i do now ? Big thx for helping |
#2 | |
Are the high beams on your headlights HID's or are they regular bulbs?
| Dimmed high beam as DRL? | Ot_tO | Cosmetic Modifications (Exterior/Interior) | 5 | 08-21-2012 12:34 AM |
| DRL: Low beam or -lamps - or not? | Ot_tO | General Yaris / Vitz Discussion | 10 | 07-27-2012 07:11 AM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
| hid hi/low. question on using high beam for DRL! | marcus | Cosmetic Modifications (Exterior/Interior) | 22 | 06-17-2010 03:12 PM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
