Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Europe (continental)
Old 08-28-2012, 02:48 PM   #1
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
At first I was thinking you are nuts, but then I realized that the radio probably has a super cap for memory backup. When you remove the radio it keeps the CMOS alive for a long time, but when you leave it in circuit, it tries to power the rest of the car when you pull the battery cable. Put a general purpose diode (1N4001, etc) in line with the constant battery power wire, with the white line facing towards the radio. That will prevent it from back feeding the rest of the car.
Thanks CT.
I, too thought I was "losing it" so I had to do it 3 times and sure enough, each time the results were the same. I was thinking about the diode, but have not had the motivation to getting into the dash again. It just might be the same with the Yaris radios too...
bobolinko is offline   Reply With Quote
Old 08-28-2012, 02:51 PM   #2
Originally Posted by bobolinko View Post
Thanks CT.
No. The Yaris ones lose it instantly either way, which would lead me to believe that the Scion harness or fuse panel has the diode integrated.
HELP, CAR SUDDENLY GOT LEAN Faraz_Shaikh Forced Induction Forum 26 03-31-2011 08:54 PM
HELP, my car is completely DEAD!!! Arlyarlz General Yaris / Vitz Discussion 18 07-19-2009 04:03 AM
3rd 360 dead, do I move to PS3 ? Dbeau Off-topic / Other Cars / Everything else Discussions 18 04-27-2009 09:04 AM
aftermarket dead pedal dtappe4926 General Yaris / Vitz Discussion 12 03-19-2009 01:38 AM
