Old 03-24-2007, 01:52 AM   #1
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Get a JDM rear torsion beam with disks on it. That is about it currently.
Old 03-24-2007, 02:07 PM   #2
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
That's what I was thinking. For mostly daily driving, though, there are other ways to drastically improve braking without dumping $1000 into a new rear end.
For instance:
-upgraded pads for the front brakes
-stainless steel brake lines (the best upgrade, IMO)
-higher temperature brake fluid (I've had great results from Motul)
-upgraded master cylinder (back to that money thing, though)
Remember, you may actually lose braking power (and thus, take longer to stop) by switching to rear disc brakes- vehicles like ours do not have EBD, and the "old style" proportioning valves are set up for drums- you can get around this by swapping out the master cylinder and lines, as well- but, oh the $$$ you'll be spending! Drums are lighter, too, so there's less unsprung weight.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
Old 03-24-2007, 02:39 PM   #3
largeorangefont
Break'em off some.
For instance:
Agreed, except you forgot the most important braking mod. Better tires :)
I would do tires, then SS lines and fluid, and after that better pads if you need them.
The problem is there are no SS lines available yet. I will get them the day they come to market though.
The proportioning may be different with the rear disk setup (no idea if it is or not), so it may require the master cylinder to be swapped out as well to make it "correct". since the vas majority are non ABS it may be less critical, but still should not be overlooked.
Old 03-24-2007, 05:26 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
Um, why change the master cylinder? there are these new things they have been using since god knows why called proportioning valves. All we would have to do is change that to get the proportioning, I am sure that would be a lot cheeper to get ahold of than a whole set up off a JDM Vitz
Old 03-25-2007, 01:43 AM   #5
largeorangefont
Break'em off some.
Read Moose's post at the top of the thread. He is right.
I'm not sure if the rear disc cars use a different master cylinder. If they do there is probably a reason why. Running out of fluid to actuate your brakes is not something you want to do.
Old 05-17-2007, 03:13 AM   #6
Terrorize
Toyota Newb!!
Drives: Yaris S Sedan w/ Aero Package!
Hmm..my Yaris sedan has EBD apparently...how can i tell???
Up here in Canada..it was optional...but the package i chose supposedly has it...
For instance:
Terrorize is offline   Reply With Quote
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 06:23 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 02:44 PM
Big Brake kits for Yaris 5 door mojoyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-23-2007 01:30 AM
Loose brake discs Garioch DIY / Maintenance / Service 4 03-07-2007 10:44 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 12:26 PM
