![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Causes of slightly more worn inside and outside edges?
I replaced my tires after getting nearly 100,000 miles out of them (Yes that's correct...and the centers STILL had a bit of meat left!) and noticed that the edges though on pretty much all four tires were worn down near bald on the inside and outer sides. Is there any cause for this? I do have tein springs and a rear sway bar but those shouldn't affect the edges like that would it? The alignment has always been pretty good too, within spec.
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
Form>Function
what were your camber specs set at? Lowering the car should not have too much camber effect on the rear but it still may have been slightly altered?
Are you cornering hard ever? |
All four corners, under-inflated would be my initial guess.
I don't have the specs numbers on me but I know when I get an alignment check every so often, they are always in spec and if they are not, they get fixed. I do admittingly take some corners fast every so often but not all the time. Would fast corners wear the inside and outer edges out?
Form>Function
without proper inflation, pushing the car to its limits could put more stress on the tires in the wrong areas/ways.
Unless you have aftermarket camber arms/plates/bolts/shims to recorrect you could still have the camber knocked out spec. |
Yes, under-inflation is the textbook cause of simultaneous wear on both outer edges. Over-inflation on the other hand causes center wear.
Hard cornering wouldn't cause inside and outside edge wear? I'm just trying to solve this one and know for sure what caused it
Hard cornering is just one factor. Alignment and tire pressure are other factors. I think toe being off is the number 1 killer for tires, followed by camber...if we're just looking at alignment.
FWIW guys, my race tires, which I do drive on the street a bit, have the same kinda wear.
-1.5* camber wears out the inner edge, and racing kills the outer edge. OP, if you don't race teh car, it's either your inflation pressure or a very screwed up alignment lol
#11 | |
It must be the tire pressure then because I always made sure the alignment was in spec. It's lowered and has a rear sway bar but yeah, it was ALWAYS in spec, especially the rears. I never had an issue with them
#13 | |
