![]() Drives: yaris 07 Join Date: Feb 2012
how to smoke headlights ?
i bought a vans spray tint for headlights ?
it's all written in japan can someone tell me instructions how to use it ? :| http://www.tunersdepot.com/Lighting/...ml--96440.html |
the usual way to spray anything... clean it well so there's no dust or oil, spray light coats, let it dry between coats, until it's dark enough to your liking...
You can try using window tinting for replacement
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
Dont forget to mask it off
![]() ![]() Drives: Want a yaris Join Date: May 2012
Ideally, remove the headlight. Will make the job much easier.
I did my dodge stealth years ago and it turned out really nice on the tail lights. Take your time. Most headlights have a protective coating that must be sanded off (takes forever) if you want it to come out right. Sanding is very important. When you finish sanding, sand them again. When spraying, go with super light coats and let them dry in between coats. When spraying, stop one shade lighter than what you want the finished product to be. Then apply a few coats of clear and it will slightly darken more and provide protection. Use quality clear coat and wax it a few days after you finish. |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 02:31 AM |
| 2010 yaris Projector headlights | yaris2010RS | Items for Sale by private party | 9 | 01-09-2012 05:31 PM |
| Headlights | Dpudg | General Yaris / Vitz Discussion | 5 | 09-04-2011 03:18 PM |
| Best Aftermarket Headlights | MadMax | Cosmetic Modifications (Exterior/Interior) | 3 | 06-04-2009 06:50 PM |
