Old 09-03-2012, 04:40 PM   #1
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
How is the driveability with these?
The drive ability feels like a stock car, doesn't behave much differently. if anything it feels a little MORE like a RWD car because the front sway bar was removed. but after 500 miles of mountain back road driving to and from vermont i would say it handles very well still. (i/we were not pushing the car to its limits, but for swift backroad driving it felt as good as when i was just on springs)
Are they stiff?
the drive height setting isn't that stiff or bouncy. it doesnt feel much harder than when the car was on micro image springs. i never paid too much attention to how stiff it was before but i can say that it doesn't fell that bad at all. its a lot less stiff than my boyfriends R32 on H&R street coilovers(and some other suspension mods). BUT the way the system works is if you air the car up REALLY high the ride will be VERY stiff and VERY bouncy. the bags are like the springs, so airing it up high means a lot of PSI in the bags and a hard ride. but the regular drive height i use is pretty nice.
Can you adjust dampening or only height?
the struts i have (and i cannot guarantee the struts that we are working on getting will be 100% the same) uses a threaded strut with a collard bag (think coilover) and they DO have adjustable dampening. hopefully the kits we are working on feature the same things. pretty much you'll get your struts, wind the bag all the way down and lock it into place.. i mean everyone wants max lowness right :)
Is there a weight limit? What is maintenance like?
no weight limit that i know of. we have had myself and 3 passengers plus some luggage in the car and all i had to do was air the bags up a little extra to compensate for the weight. the management i use offers 8 different presets so you can have quick settings to go to, or use manual mode and air up each corner independently.
maintenance: empty the water traps and tank from time to time. only other problem i have had was a fuse in the system for the compressor, which is convienently located under the hood, has blown out twice. this happens from time to time on everyone we know with air ride. so during install, either professional or yourself, make sure to leave it easily accessible. possibly may have to add some anti-freeze(like semi trucks or regular air compressors) to the tank and lines for winter but we will see if that is needed.
Do the pumps ever go out?
like above the compressors have not had a problem, only the fuse. my kit uses (2) 380CC vlair compressors. they are pretty high quality and i believe i have 2 so that they work together and faster rather than making one compressor do all the work and put a lot of stress on it.
hopefully these answered your questions, they were very good ones i'm glad someone asked. if anyone else is curious feel free to ask :) i wanna help the community as much as i can and grow our aftermarket support :)
DINOeggxo is offline   Reply With Quote
Old 09-06-2012, 03:07 PM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Great info thanks. Im sure it will be great help for others in the future.
The last question I have is how do the bags work like springs? Do they compress? If so do you have to refill the bags after big bumps? If they don't compress, how is there any compression and rebound?
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 12:59 PM
DIY - Cabin air filter location (Belta, Vios, Yaris sedan) Murtaza_murti DIY / Maintenance / Service 5 04-05-2012 11:03 AM
Tata Motors to introduce Air Car - Is it the next big thing? *MAD DOG* Off-topic / Other Cars / Everything else Discussions 24 09-29-2010 11:42 AM
Autoloc Air Bag Suspension System Malaya1221 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 04-24-2009 10:53 AM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 05:46 PM
