Old 09-03-2012, 07:01 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
are you running negative camber not he front? Wouldn't you get better traction with 0°
Old 09-03-2012, 07:10 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Yes, I didnt feel like changing my alignment because I autocross a couple times a month.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 09-03-2012, 07:11 PM   #3
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
^ One of the things that I need to do as well is still learn the perfect shift point. One of the suggestions that a lot of folks in the LSR crowd suggest is that even if you have a shift light your eyes tend to center on the tach many times and therefore placing a piece of tape on to provide the quick eye recognition will ensure that if you are happening to look that way instead of the shift light it will help.
A shift light is something I have wanted to get!
Ptuning.com
Old 09-03-2012, 07:39 PM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I will need one for sure by next summer with all of the things that I will need to be monitoring that is for sure.
