Old 09-07-2012, 08:12 AM   #1
Steveh27
Drives: 2010 3dr hatchback auto red
hose
Does this hose drain the water coming in the vents below the windshield? My 2010 has fine mesh screening the debris from going in there.
Does it also drain the AC condensate?
I'll pull it off & check in a bit.
Steveh27 is offline   Reply With Quote
Old 09-07-2012, 08:22 AM   #2
The hose only drains the condensate. The vents by the windshield drain to the wiper tray. The air entering the A/C system goes down through those holes, back up and then straight back through the firewall. That path keeps water from entering.
Old 09-07-2012, 09:54 AM   #3
Steveh27
Thanks CTScott. I'm at the dealer right now. They're doing the oil change & will check to make sure the bottom of the hose drain is clear & will show me where that is.
Old 09-07-2012, 11:42 AM   #4
Steveh27
OK
The dealer said there were many spider webs under the car & that 1 one of them may have gotten in the drain & been the clog. They did clean it out from the bottom - no charge with the oil change.
That makes sense as I've had the cabin filter for 2 years to prevent stuff getting sucked into the airbox.
They said to wash off the bottom of the car frequently to keep the spiders down.
Old 09-07-2012, 12:23 PM   #5
Interesting. I wouldn't have thought of little critters going in the out door.
Air Conditioner kick-in?? churp General Yaris / Vitz Discussion 5 05-26-2007 08:43 AM
Air Conditioner Noise Cathy General Yaris / Vitz Discussion 16 05-08-2007 02:08 AM
Air Flow switch problem aucorium DIY / Maintenance / Service 5 01-15-2007 04:54 PM
1.3 Ltr Yaris Air Filter mods aucorium Performance Modifications 9 08-18-2006 08:32 AM
