Old 09-07-2012, 12:25 PM   #1
I just need to get my hands on a 2012 to sniff the CAN bus messages to see if body ECU ones are the same as for the prior generation.
Old 09-07-2012, 01:54 PM   #2
veewonwon
Drives: '12 Yaris SE 5MT
While you're checking the code out, I wonder if you can see if the flashing can be turned off during locking and unlocking activities. I would prefer not to have any signs at all.
Many thanks.
veewonwon is offline   Reply With Quote
Old 09-07-2012, 02:49 PM   #3
Many thanks.
For the 2012's here are the "customize parameters" via TechStream:
Wireless Control - Function that turns wireless door lock / OFF or ON
Hazard Answer Back - When the doors are locked by wireless operation, the hazard warning lights flash once.
When the doors are unlocked by wireless operation, the hazard warning lights flash twice.
Unlock 2 Operation - Function that unlocks driver door when unlock switch on door control transmitter module set sub-assembly is pressed once, and unlocks all doors when pressed twice. If setting is OFF, pressing unlock switch once makes all doors unlock.
Panic Function - Function to operate theft deterrent system by continuously pressing panic switch on door control transmitter module set sub-assembly for 0.8 seconds
Auto Lock Time - (30, 60, or 120 s) Function that regulates the interval between unlocking and automatic relocking of doors
Wireless Auto Lock - This function turns the wireless auto lock function on or off.
Old 09-07-2012, 04:36 PM   #4
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Many thanks.
Referencing ctscotts post, in techstream customize menu, you would want the hazard answer back turned off.....
MicroImageonline forums - Shroomster
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 09-07-2012, 07:29 PM   #5
veewonwon
Thanks for the keyword "hazard answer back", I was able to search the relevant thread.
So I guess I've to visit my dealer to perform this change, and there is no DIY method available for the MY2012.
