Old 09-09-2012, 08:44 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Thanks everybody! I also heard AGM are the best. I am buying one today, battery died again 2 days ago. The stock battery has been in my Yaris for 6 years, finally giving up.
caineroad is offline   Reply With Quote
Old 09-09-2012, 06:12 PM   #2
nookandcrannycar
1500 miles more North than due NE (Houston to Toronto) would definitely cause different things to be important to different buyers. I want a widespread (geographically) guarantee I can use if the extreme heat makes the battery crap out. I assume your performance concerns would be opposite of mine and most pronounced at a different time of year. Congrats re 6 years on your original battery!
Old 09-09-2012, 08:57 PM   #3
nookandcrannycar
MISTAKE BY TECH -- ASSIST MGR OF WAL-MART SAID MAY USE INSURANCE
I made post #9 and most of the ones before it at a Starbucks. I had driven 63 miles after leaving Wal-Mart with the new battery installed. As I mentioned earlier in this thread, everything was 'cleared up excet I had this new roughness at idle that wasn't there before the battery install. After leaving Starbucks after post #9 I drove about 20 miles on surface streets. It didn't get any better. I pulled into the Kroger grocery store parking lot and shopped for just a few items. When I returned, I decided to take a picture of the new battery. I popped open the hood of my Yaris...AND I NOTICED THAT THE AIR FILTER BOX WAS APART WITH THE AIR FILTER EXPOSED. I assume the box had to be opened to get the old battery out. The new battery was installed, and the TECH PUT THE AIR FILTER BACK BUT DIDN'T FIT THE BOX BACK TOGETHER AND THUS DIDN'T PUT THE CLAMP ON. I SNAPPED IT BACK TOGETHER AND RECLAMPED IT. The IDLING got a LITTLE bit better. I did a few inteernet searches re this subject. My conclusion was that the first thing to do (car wise) is replace the air filter. I drove back to the Wal-Mart and talked to the Assistant Manager (Manager off), and we left it that I would ask a Toyota dealer what the next thing to do would be and then pay her a visit tomorrow (she's expecting me).
******What damage could have occurred by driving 63 miles with the air filter housing split open like that?******************
Old 09-09-2012, 09:44 PM   #4
Chances are it is just a coincidence and that no damage was done. There is a TSB about running rough after disconnecting the battery that pegs the throttle body needing cleaning as the culprit. Disconnecting the battery clears the short term fuel trims, so the ECM has to do some relearning. If the ECM got used to a dirty TB, it can take quite a while for it to be happy with it again.
Old 09-10-2012, 06:13 AM   #5
nookandcrannycar
Thanks! It is a little better this morning. While I was at Wal-Mart getting the new battery the four words 'ECM needs to relearn' kept running through my head, so I wonder if I skimmed that thread at some point. Lippitt posted a link to my other post about this and I followed that to two links posted by Altitude...one of which brought me to a post by yaris-me that reads "run a good fuel system cleaner". I know that thread wasn't specific to idle behavior after a battery disconnect, but if my idle doesn't return to what it was before the battery replacement would 'running a good fuel system cleaner' help my specific idle issue? If so, is there a 'good fuel system cleaner' that you would recommend?
Old 09-10-2012, 06:56 AM   #6
A fuel system cleaner won't help. Pick up a can of throttle body cleaner. The best way to clean it is to unbolt it so you can easily clean the entire inside of it.
Old 09-10-2012, 07:04 AM   #7
nookandcrannycar
Thanks!
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
