Old 09-10-2012, 06:56 AM   #11
Originally Posted by nookandcrannycar View Post
Thanks! It is a little better this morning. While I was at Wal-Mart getting the new battery the four words 'ECM needs to relearn' kept running through my head, so I wonder if I skimmed that thread at some point. Lippitt posted a link to my other post about this and I followed that to two links posted by Altitude...one of which brought me to a post by yaris-me that reads "run a good fuel system cleaner". I know that thread wasn't specific to idle behavior after a battery disconnect, but if my idle doesn't return to what it was before the battery replacement would 'running a good fuel system cleaner' help my specific idle issue? If so, is there a 'good fuel system cleaner' that you would recommend?
A fuel system cleaner won't help. Pick up a can of throttle body cleaner. The best way to clean it is to unbolt it so you can easily clean the entire inside of it.
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 09:34 PM
Charging voltage for stock battery Vinceb DIY / Maintenance / Service 3 02-12-2011 12:10 AM
