Old 05-04-2012, 01:56 PM   #1009
Jason@SportsCar
Originally Posted by Bluevitz-rs View Post
Sweeeet!! Sounds like 4th gear could have been a hair longer though but close gears are so much better.
No, 5th needs to be shorter, its not 1-1.
Old 08-30-2012, 05:53 PM   #1010
Jason@SportsCar
Heading up to Buttonwillow this weekend for the final Double National road race of the season before the Runoffs. Looks like a good H Prod field, with five cars. Unfortunately Jamie could not make it, so the 2012 Yaris will sit this one out.
http://www.calclub.com/html/html2/ar...2-Schedule.pdf
Old 08-30-2012, 06:58 PM   #1011
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Best of luck...I have the last LSR this weekend and am hoping to break the record that I set in July.
Old 09-04-2012, 01:56 PM   #1012
Jason@SportsCar
Well the race on Saturday did not go to plan, six laps into the race after stating on the pole I had half a lap on the rest of H Prod... Then a flat tire. DNF.
Sunday started first again, and cruised around just fast enough to win the race.
Being the last class of the day there was a lot of junk on the track, so easy to pick up something a kill a tire.
Old 09-04-2012, 05:31 PM   #1013
Looks like you were ready to drag race instead....at least it was something out of your control.
Old 09-04-2012, 05:37 PM   #1014
justjesus
justjesus's Avatar
Drives: 2008 Liftback
OUCH!
man, that really sucks!!!
Old 09-04-2012, 05:38 PM   #1015
justjesus
justjesus's Avatar
Maybe I will work on my competition license, so if you ever need a back up driver....hehehehe
Old 09-05-2012, 01:27 PM   #1016
Jason@SportsCar
In less than a week our cars ship to the Runoffs... So this is the perfect day to order a new final drive gear set, six new wheels, and 18 more tires. I think its going to be a bit of a thrash come the weekend.
Old 09-07-2012, 11:54 AM   #1017
Jason@SportsCar
Here are a the opening laps from Sundays race (from the 2nd place finisher). I was sleeping at the start, expected them to wave the green much later down the strait, so I was not paying attention and in the wrong gear.
http://www.youtube.com/watch?v=53SGe...ature=youtu.be
Old 09-07-2012, 12:45 PM   #1018
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
entertaining to watch his rear view mirror. Congrats
-Derrick-
Old 09-07-2012, 06:35 PM   #1019
Jason@SportsCar
Following last weekends race we decided to make a few changes to the 99 car... While overall we have been extremely happy with it this year - the close-ratio gear set Micro Image found is awesome, and the Loyning's head with Jun cams is a big leap over our previous setup - but I just could not match the corner speed of the new 2012 car.
So calls were made, parts were ordered, and we will now be running a setup much closer to the one on the 2012. The 13" wheels are coming off, and we will move up to the taller and wider 15" Hoosier slick. To offset the new tires bigger circumference the trans had to come out and the the stock final drive was replaced with the xB gear set. Then the ride height goes down, and spring rates go up.
We think this is a step in the right direction, but its to late to turn back now. I sure hope this is the last trans I pull this year.
I cant thank the guys at Cage Toyota (final drive set), Kaaz (gear swap), Eibach (springs), Hoosier (tires) and the Tire Rack (wheels) enough. I thought it would be impossible to do this in the short amount of time we had, but they all got me the stuff I needed in short order.
Old 09-07-2012, 07:37 PM   #1020
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Can't go wrong with rpf1's
Old 09-10-2012, 11:45 AM   #1021
Jason@SportsCar
Re-geared trans is in. New springs, ride height and alignment set. New wheels and tires on. Just needs a bath and then ready for the Runoffs at Road America.
Old 09-10-2012, 11:56 AM   #1022
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Car looks fantastic, I bet it runs better than it looks
Old 09-10-2012, 12:51 PM   #1023
justjesus
justjesus's Avatar
That wheel/tire combo and new ride height is just perfect
Old 09-10-2012, 08:22 PM   #1024
Jason@SportsCar
Great shot from the Buttonwillow race.
Old 09-10-2012, 08:59 PM   #1025
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
indeed
b20vteg is offline   Reply With Quote
Old 01-09-2013, 04:06 PM   #1026
Jason@SportsCar
Time for some off season updates...
Less than thrilled with the other options we have used in the past, we got Porterfield to cut down a set of Hawk DTC-60 pads from a different application to fit the Yaris. So looking forward to trying these out at the Auto Club Speedway U.S. Majors Double National in a few weeks.
Also time for a steering wheel upgrade. The NRG unit is inexpensive, and works great, but with no power steering (and wide slicks, a diff and power) it is hard to grip the leather wheel for 40mins. Bought myself a late xmas present, a suede OMP wheel.
Also picked up a Longacre mirror. I don't really need the extra field of vision, but we found a cool side effect using this type of mirror... If you have your video camera mounted in the car the camera can pick up nearly everything going on behind you - picture in picture.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 07:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 10:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 05:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 10:51 AM
