#1 | |
![]() Drives: Toyota Yaris - FR. 2005 Join Date: Sep 2012
I have looked at the part numbers of the actual units that are fitted. The right side door sensor is marked 89865-52010 with the letters RH prominent (the opposite of your last sentence above). The left side door sensor is marked 89835-52010. Would you agree that in accord with B1140 I should be looking for a replacement for 89865-52010? Thanks for your understanding and patience in this matter. Ed |
#2 | |
You are correct. When I pasted the part numbers above I transposed them. The EPC lists (for both LHD and RHD 01-05 Yaris): 89865-52010 as Sensor, door side air bag, RH 89835-52010 as Sensor, door side air bag, LH The easiest way to be absolutely sure is to unplug the RH sensor and then read the DTCs again. If you have the correct sensor unplugged you should still only see B1140. If you have the incorrect one unplugged then you will have a second DTC.
| Air Bag Light On? | SedanDan | DIY / Maintenance / Service | 2 | 05-23-2012 03:33 PM |
| 1.3 Ltr Yaris Air Filter mods | aucorium | Performance Modifications | 9 | 08-18-2006 08:32 AM |
