#1 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
I changed mine at about 90k miles. Mine's bearings had gone bad... it sounded AWFUL.
It started sounding weird for a bit, no signs of leaking... I knew it was coming from the belt area but didnt get it checked out before going on a 14 hour round trip and by the time I got back my engine started to sound like a dirty diesel. I took it to toyota dealership and they said it was the waterpump had gone bad. They took it out and found out it was just the bearing(s) and told me since the labor was already high to just replace it and the serp. belt. pretty expensive fix but its much better now.
-Jen <3 ![]() Quote:
#2 | |
No leak just noise. Now that the car is out of warranty (or will be in a couple years) Im wondering if I get a little leak to just run it and not fix it since Ill have to pay. But what happened to yours had to be fixed...
My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
2009 Yaris here...
Mine broke with about 20,000 miles on it.(Water pump) Toyota replaced it for free. |
Modded Moderator
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was service related. I've moved it to the proper sections
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| HELP: changing water pump | dlplunkett44 | DIY / Maintenance / Service | 4 | 02-06-2011 09:26 AM |
| Water Pump being replaced... Rental Car! | slothman86 | DIY / Maintenance / Service | 12 | 08-11-2010 04:14 AM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
