![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
if you put it in neutral with automatic transm. would it be ok to change it to Drive while moving ?
#2 | |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
If I had an automatic transmission .. I would take my foot off the gas and use DFCO as much as I could but leave the car in gear to lessen the wear on the transmission. |
#3 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I don't coast in neutral with my stick because when the engine is idling it's still using gas, whereas coasting in gear raises the engine rpms above idle and activates the DFCO. Then it doesn't matter how fast the engine is turning because it's not using any gas anyways. Just stick it in 5th and put both feet on the floorboard.
| Using DFCO to increase your MPG | BailOut | Fuel Economy Forum | 216 | 08-30-2018 04:15 AM |
| Kinetics, coasting, and you | sbergman27 | Fuel Economy Forum | 18 | 05-08-2010 01:25 PM |
| Coasting in neutral | bankrobber | Fuel Economy Forum | 9 | 03-11-2010 03:55 PM |
| 2004 yaris hatch, 2nz-fe, DFCO in all gears? | toyo | Fuel Economy Forum | 11 | 06-26-2009 02:21 PM |
| So Close!!!! | aclark246 | Fuel Economy Forum | 13 | 06-07-2009 10:02 AM |
