Old 09-17-2012, 09:44 PM   #1
VitzNCP91
Drives: 2007 Yaris
Sorry to reopen, but is there a section where it can tell how to remove the speedomter's needle. Any info will be greatly appreciated.
VitzNCP91 is offline   Reply With Quote
Old 09-17-2012, 10:14 PM   #2
The needle is just pressed onto the servo that drives it, so you carefully pull it off. I suggest making a small mark across the clear to grey area at the base of the needle, so you can align it correctly when you put it back on. When you do press it back on, hold the back of the servo assembly to avoid damaging the tiny plastic gears inside, while pressing the needle assembly back on.
F/S Blue Stitched Leather Shift Boot. 1NZYaris1 Items for Sale by private party 9 05-06-2009 11:59 PM
Bayou Blue paint code andru47 General Yaris / Vitz Discussion 7 01-03-2009 04:19 PM
Blue Film over gauges Jeff1 DIY / Maintenance / Service 10 10-21-2008 03:01 PM
Black or Blue CrashRescueFF New YARIS Purchase Forum 18 07-24-2007 07:21 PM
Nautical Blue Metallic YotaYarisUSA General Yaris / Vitz Discussion 0 04-02-2006 07:09 PM
