Still don't understand what you are talking about.
Is it rust on the rotors that you are referring to? If it is, then the answer is live with it. It happens when a car sits in a moist environment. They can begin to rust in a matter or hours. Clean right up again as soon as the car is moving and the brakes get applied. If you are not referring to your rotors, then try to clarify more. Pictures would help.
#2 | |
![]() ![]() ![]() Drives: Gray Join Date: Jun 2012
#3 | |
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
If you've got a chronic amount of rust that doesn't go away, it either indicates you're not using the brakes enough to burn off the rust, or there's an issue with the brake itself, causing one or both pads to not contact the rotor. Since it's a 2012, it's very unlikely that there's any issue with the brakes. Brake a little harder and the rust will get worn off. A paper towel won't get the rust off that's on the part of the rotor that's inbetween the pads, and it also won't clean off the rust that's on the pads themselves. A lot of people are scared to drive their cars "hard", but the engine and brakes benefit from it every so often. Finally, an additional commentary, a lot of "lightly driven" cars that have rear disc brakes have issues with the rear brakes seizing up due to a lack of heat, which never ends up burning off condensation and rust from the various brake components.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| one brake light out | xartrax | DIY / Maintenance / Service | 3 | 01-27-2011 12:40 PM |
| New brake pads and noise | eii | DIY / Maintenance / Service | 8 | 06-25-2009 10:49 AM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
