Old 09-20-2012, 09:32 AM   #1
Tomatogrower
The Flying Tomato
Tomatogrower's Avatar
Drives: 2009 Red Yaris Hatchback
I would double check the TAIL fuse, as only that and the 120A ALT fuse are in circuit with the tails. Since they worked for a bit and then went out, the fuse may have opened less catastrophically than if it blew due to a short.
The only other thing that may have gotten damaged is the T-LP relay, but that it integrated into the internals of the body ECU, so to replace it you would have to replace the entire under dash fuse panel assembly.
I will check again, however, I have one of those fuse checkers with the illumination lights; the light on the fuse checker would turn on if the fuse is working ok, and it did that. Hopefully it isn't the T-LP relay; that would suck
Tomatogrower is offline   Reply With Quote
Old 09-20-2012, 11:11 AM   #2
Also, if you haven't done so already, disconnect that red wire from the OEM wiring to make sure that it is not just a case where something failed within the switch, preventing the T-LP relay from activating.
Tags
diy, fog lights, installation, wires
Fog light jumping question netz2008 DIY / Maintenance / Service 1 01-16-2012 09:55 PM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
rear fog light and tuned rear lights lefti696 Cosmetic Modifications (Exterior/Interior) 0 11-09-2006 03:06 PM
