Old 09-21-2012, 02:44 PM   #1
bentjazz
Drives: 2009 Yaris--3dr MT
pink radiator fluid
I've read on this forum that the water pump problems with the Yaris might be attributable to the pink radiator fluid that is standard. Can one change out this pink fluid for a different type of fluid that might not be as problematic for the water pumps?
Thanks.
bentjazz is offline   Reply With Quote
Old 09-21-2012, 03:06 PM   #2
bronsin
bronsin's Avatar
Sure. Just drain the radiator at the drain on the lower left side of the red. On my ECHO all the coolant came out without resorting to the block drain.
I think it unlikely the coolant is responsible however.
Perhaps others will weigh in?
Old 09-21-2012, 03:40 PM   #3
Klink10
Klink10's Avatar
Might do some more in depth reading about the fluids and waterpump failure. If you got some cheap "pink", I'll take it.
Old 09-21-2012, 04:07 PM   #4
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
the pink stuff is Toyota long life fluid and i doubt its the cause of a water pump failure
pennyracer is offline   Reply With Quote
Old 09-27-2012, 05:33 PM   #5
Eli Lilly
Drives: 08 Yaris Sedan
Not the fluid itself, but it kinda seems like it won't support the extended change interval. The red had a change interval of something like 30K, the pink brought that up to 100k. My guess is the corrosion additives in the pink aren't lasting quite that long in all situations.
-E
Eli Lilly is offline   Reply With Quote
Old 09-21-2012, 04:14 PM   #6
Point to some of the statements making this proclamation. I don't recall any.
Since the lifespan of pumps has varied so greatly over the life of this forum, I'd day there is definitely no problem with Toyota Pink. Many are still running with their original, myself included. A few have had early failures, and some have done replacements well beyond 100K miles.
It's totally random.
Old 09-21-2012, 08:39 PM   #7
My bet is that the premature pump failures are far more attributable to the lack of a screw-type belt tension adjustor than they are to anything else.
Old 09-21-2012, 08:57 PM   #8
bronsin
bronsin's Avatar
MAybe. But I NEVER heard of wp failures in the ECHO and they are the same engine?
Old 09-21-2012, 09:07 PM   #9
Different belt setup (or at least load) though, with the hydraulic power steering on the Echo. The EPS puts an incredible load on the alternator, which results in a lot more belt tension against the water pump pulley.
Old 09-22-2012, 12:54 PM   #10
Drummer829
Drives: future prius
My uncle who is a mechanic at toyota did say the pink coolant from toyota is not good and does cause some of the waterpump problems.
Drummer829 is offline   Reply With Quote
Old 09-22-2012, 01:30 PM   #11
Astroman
Modded Moderator
Astroman's Avatar
Please try to post your threads in the correct thread section. It's getting old moving all the stuff from the "general discussion" when this was clearly service. I've moved it to the correct section
Old 09-22-2012, 11:29 PM   #12
pennyracer
boydstir
pennyracer's Avatar
ya thats why toyotas never last
i dont beleave that for one second
Old 09-23-2012, 07:45 PM   #13
nookandcrannycar
Extremely interesting. The steering is definitely different than any of the other cars i've owned.
Old 09-25-2012, 03:14 AM   #14
bankrobber
Drives: 2007 Yaris Hatchback
A little off subject but I replaced my belt with a lifetime one from AutoZone. I cant seem to keep it tight very long. I get it tight then a few days later it will scream when I start it cold. Not sure if the belt is stretching or the bolt losening up. Think I will try to put some marks to tell. Have aftermarket belts had problems?
bankrobber is offline   Reply With Quote
Old 09-25-2012, 07:35 AM   #15
I hate it when people derail threads with off-topic questions, but Autozone belts are junk. I made the mistake of using one on Crashy2 when I reinstalled her A/C, and I have had to tighten it three times since the installation.
Old 09-23-2012, 02:05 PM   #16
Geoff Peace
Drives: Yaris 1.33 litre 2011
Thanks.
I assume that the 'pink fluid' is Toyo super long life coolant which has a life of ten years. I wonder, does it really last ten years? It may well do in terms of not freezing but I am very doubtful with regard to the anti corrosion inhibitor and the lubricant which is present in all antifreeze. The lubricant plays a vital part in prolonging the life of the sealing gland in the coolant pump. Perhaps if the coolant was changed more frequently, say every three years pumps would last longer. Antifreeze is cheaper than coolant pumps, I suspect that ten year antifreeze is more to do with the anti polution brigade rather than prolonging the life of the coolant pump, and in the case of corrosion inhibitor the cylinder head gasket.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 09-25-2012, 07:58 AM   #17
bankrobber
Thanks CTScott. I've always been a little worried about fetting the belt too tight and burning up the water pump. Mine is still OEM with 155k
Antifreeze oozing pink powder from filler neck PICS auxmike DIY / Maintenance / Service 7 06-08-2010 12:03 AM
Pink Sony DSC-W120 Used crk06c Items for Sale by private party 1 03-30-2010 11:12 AM
Kustom Play's OG Pink Steering Wheel OMG WOWZ HI2U kustom play Items for Sale by private party 8 02-11-2010 09:25 PM
PRETTY... IN PINK? Noelia Photo-Video-Media Gallery 16 10-15-2009 08:10 AM
Blackberry Curve 8330 Pink RacerFreakXXX Items for Sale by private party 6 04-17-2009 12:57 AM
