Old 09-21-2012, 11:34 PM   #1
chriswf
Drives: Scion tC and Saturn SL1
Any specific brand? Just like Kyrlon or Duplicolor? Lol.
chriswf is offline   Reply With Quote
Old 09-22-2012, 07:51 AM   #2
I use Krylon. My experience is that it goes on better and tends to last better than Duplicolor or Rustoleum. Just do a couple of coats of clear over the white to protect it and make it easier to clean them.
Old 09-22-2012, 08:33 AM   #3
chriswf
Should I scuff the wheels? Like with a scotch bright pad? Or 180 grit? Or 320 grit?
OR is that not necessary?
I used to work in a body shop but I never painted a single wheel - at least not on purpose lol.
And I really don't know how well aerosol paints stick to smooth surfaces.
Old 09-22-2012, 08:55 AM   #4
Definitely, scuff them up. Use 80 or 100 girt sandpaper or one of the coarse scotch pads. Also, use the Krylon primer before the paint. Because of the depth of the indented area, you will get a lot of texture (since the overspray kind of hangs there and gets picked up by the paint). That means that you will need to do some sanding between coats (I usually use a fine scotch pad for that part).
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
WHITE Yaris paint touch up + silver dashbaord scratch repair marcus25 Wash, Wax, Detailing, Exterior Repairs 1 08-26-2010 12:11 PM
Toyota OEM Paint Code for steelies? Snappy Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-07-2010 01:34 PM
Matching spray paint to Polar White jdubau55 Cosmetic Modifications (Exterior/Interior) 1 03-13-2007 06:01 PM
