Old 09-23-2012, 01:52 PM   #1
MadMax
MadMax's Avatar
It's nothing to worry about, your rotors are bare metal and a little surface rust will happen when they get wet. In extreme conditions, your brakes can even "lock up" a little requiring a bit of forward movement to break free (this used to happen to my Passat in Belgium). But for the most part, they will clear up as soon as you use your brakes.
I travel a lot for work and if we get any rain while I am gone, my brakes usually are covered in surface rust when I get back. I just returned from being gone a week, and this is what mine look like...
It's nothing to worry about, it'll clear after a mile or so of driving and there is no advantage to trying to clean it off beforehand...
Cheers! M2
Old 10-22-2012, 09:44 AM   #2
YodaBird
Drives: Gray
Cheers! M2
The rust isn't on the pads where it brakes, it's in-between and around the edges, there isn't any way to clean this off, no chemical you can spray on and after driving a little it comes off ?
YodaBird is offline   Reply With Quote
Old 10-22-2012, 09:52 AM   #3
bronsin
bronsin's Avatar
Every car with disc brakes has rust like this.
Dont be concerned.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
New brake pads and noise eii DIY / Maintenance / Service 8 06-25-2009 10:49 AM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
