Old 09-27-2012, 11:00 AM   #1
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
There is none on the 2012. The fog light relay is built into the body ECU.
To see if it is enabled on your car, you can jump pin 3 to pin 4 on the headlight switch connector D106. Pin 3 will be brown or green (depending on if you have the OEM alarm) and Pin 4 will be green.
Jump those wires and have the ignition on and the headlight switch in the low beam position. If the fogs don't light then the relay is not in there. For the 2nd gens for instance the integrated relay for the power windows and locks is not present on cars that were not built with them (and there are different part number for the body ECU).
Attachment 48579
Thank you, I was getting that impression from reading the Prius C forums.
The fog harness behind the bumper is already there, as is the fog fuse.
I do not have the OEM alarm, so brown to green?
What wire is the parking light, if I cheese to not use low beam?
Is the illustration pin side, or wire side?
Again, thank you!
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 09-27-2012, 11:14 AM   #2
Again, thank you!
If you have the alarm or DRLs - Green to brown.
If you have neither alarm nor DRLs - Green to Green.
The connector illustration is looking at the pin side of the connector.
For the parking light turn on, it is a bit more complicated for the 2012, as for the ones with DRLs, that functionality is built into the body ECU, so it will be completely different for DRL vs. non-DRL Yaris. I would start with seeing if it works at all on a non-factory equipped car.
Old 09-27-2012, 11:18 AM   #3
Absolutely Red 12
Asshole
Got it, will let you know tonight.
Thanks again!
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
