Old 09-27-2012, 11:14 AM   #4
Originally Posted by Absolutely Red 12 View Post
Thank you, I was getting that impression from reading the Prius C forums.
The fog harness behind the bumper is already there, as is the fog fuse.
I do not have the OEM alarm, so brown to green?
What wire is the parking light, if I cheese to not use low beam?
Is the illustration pin side, or wire side?
Again, thank you!
If you have the alarm or DRLs - Green to brown.
If you have neither alarm nor DRLs - Green to Green.
The connector illustration is looking at the pin side of the connector.
For the parking light turn on, it is a bit more complicated for the 2012, as for the ones with DRLs, that functionality is built into the body ECU, so it will be completely different for DRL vs. non-DRL Yaris. I would start with seeing if it works at all on a non-factory equipped car.
2012 Fog Light Kits TimmyTwo2 Third Gen Yaris General Discussion 4 10-06-2014 03:41 PM
2012 Fog lights FIY Absolutely Red 12 Third Gen Yaris General Discussion 1 09-17-2012 10:31 PM
2012 Yaris LB Fog Lights TimmyTwo2 Cosmetic Modifications (Exterior/Interior) 6 03-21-2012 04:54 PM
Need fog light switch and relay Jrilla DIY / Maintenance / Service 23 07-01-2011 11:12 AM
