#1 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
No DRLs.
Also now using a PIAA switch, as the cheap Chinese Toyota looking switch would not allow the fogs to turn off. New switch is a 3 wire, internal lighting, when on. It also allows the dash icon to turn on!!
Cheapest DD I could find!! |
#3 | |
I just noticed that for both the DRL and non-DRL Yaris the fog relay coil is tied directly to the body ECU internally in such a way that it prevents the fogs from turning on except when it decides it is OK to. You would have to either do some surgery on the body ECU or use an external relay and rewire the fogs to it to override that behavior.
#4 | |
Asshole
The Chinese switch was a four, with isolated illumination. Wouldn't allow the fogs to turn off!! The three wire works as expected, Ill get another 4 wire to avoid future issues. Thanks a bunch.
The one that came with the kit has some internal circuitry which ties the switching and illumination together. What you want is one where the two are truly isolated.
#6 | |
Asshole
Scott, The green wire is the trigger when the head lights lights go on, the violet loops to the other row. Looks like the Violet triggers the fog realy, and dash light. Im having difficulty finding the wire that is live when the park/low/high get selected. ![]() Do you have a wiring diagram for 2012??
#7 | |
The blue wire in pin 18 is the one that is activated when the park or headlights are on. It is 12V with them off and then switches to ground with them on.
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| 2012 Fog Light Kits | TimmyTwo2 | Third Gen Yaris General Discussion | 4 | 10-06-2014 03:41 PM |
| 2012 Fog lights FIY | Absolutely Red 12 | Third Gen Yaris General Discussion | 1 | 09-17-2012 10:31 PM |
| 2012 Yaris LB Fog Lights | TimmyTwo2 | Cosmetic Modifications (Exterior/Interior) | 6 | 03-21-2012 04:54 PM |
| Need fog light switch and relay | Jrilla | DIY / Maintenance / Service | 23 | 07-01-2011 11:12 AM |
