Old 09-27-2012, 06:22 PM   #1
bairjo
Thank you. However, as i stated earlier, i had an after market remote starter installed. I started to investigate the pink ignition switch wire situation and found that they tapped into that same wire at the switch for the remote starter and it is a little tight in there now. I could probably tap into the wire they have going to the box they installed but will this mess up the remote starter? Or, is there another point down stream I can catch the pink wire...it disappears into a fiddle string of wires and i don't know wear it ends up.
bairjo is offline   Reply With Quote
Old 09-27-2012, 09:03 PM   #2
The pin one is typically the easiest. You can tap the remote starter wire that is attached to it, as I am sure that the onstar box draws very little current.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Scion XD LED mirror install pics aplenty enviri DIY / Maintenance / Service 76 07-21-2019 02:10 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Routing XM Antenna Wire blacksan In Car Entertainment + Electronics (audio / video / alarm) 17 05-10-2007 11:56 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
