#1 | |
The flow rate of the stock injectors / fuel pump are sufficient, but the OEM fuel maps are not, so one has to run some form of piggyback fuel management to override the OEM maps. With the supercharger the included blitz fuel controller does this, but with the US market Yaris fuel maps, we seem to run a bit leaner than the Japan market maps do. To account for that some S/C users have upgraded their injectors (but typically run very rich when not in boost {which will significantly shorten the lift of the cat}). Replacing the blitz fuel controller with a piggyback, like an AEM F/IC gives more control. The other issue with the Blitz controller is that it does not have a mechanism for fooling the ECM, when the system is in boost, so the ECM will eventually "learn" about the extra fuel that the Blitz controller dumps in under boost and will "trim" it off. Resetting the ECM on a regular basis (pulling the negative battery cable for a minute) resets the fuel trims. http://www.youtube.com/watch?v=852N-COD2Ns http://www.youtube.com/watch?v=pH3mev88hoo
| 1zz injectors suit the S/C just fine | LtNoogie | Forced Induction Forum | 51 | 04-30-2016 10:11 AM |
| FS: DeatschWerks 550cc Plug/Play injectors | Tamago | Items for Sale by private party | 4 | 06-27-2012 11:11 PM |
| Technical question about bigger injectors | LtNoogie | Forced Induction Forum | 1 | 08-14-2009 03:34 PM |
