Old 10-04-2012, 09:39 PM   #1
DevilGirl
Drives: 09 3dr LB MT
Suggestions on a good replacement clutch that's not overly expensive? Hubby was thinking of replacing it with a TRD clutch kit.
Old 10-05-2012, 08:08 AM   #2
bronsin
bronsin's Avatar
Most of the $$$$ replacing the clutch is labor.
Any clutch will probably do Im thinking although maybe someone has more knowledge of that than me.
Clutches should last forever unless you are abusing it in some way.
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 04:59 AM
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 08:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 06:20 PM
Worn or bad clutch? Tonavi DIY / Maintenance / Service 6 04-27-2009 10:11 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 12:34 PM
