Old 01-11-2013, 08:29 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
wow, new rims makes your car look like a 4x4, HAHA!
Yea dude trying to get a little more clearance. They have settled quite a bit now
Originally Posted by Benedict View Post
What tire model and size are you running? What spring rates?
Getting tight fitment on 17's will leave you with more ground clearance than weak fitment on 15's and 16's. That's why I chose 17's for my car.
It's neat seeing you work with the 17x9.75's. I considered them but bitched out because I didn't want to run that much camber on my daily.
I'm running Fallen 512s in 215/40 which is one of the best stretching tires out there just unfortunate they no longer make them, I got a wicked steal from a guy who didn't know what he had. My springs are 200/6kg front and 130/6kg rear. I went with the 17s for ground clearance as well, and because on a sedan nothing smaller than 17 looks right 15s and 16s look like baby wheels. I used to be running those 16s and I was .9" from the earth. So low I couldn't fit my stock scissor Jack between the ground and pinch weld lol.
Lol I appreciate you recognizing the effort required for ~10" wheels all around. I've been toying with the idea of running 205/40s up front but that is soooooo aggressive for a DD.
Old 01-12-2013, 04:50 AM   #2
Benedict
Drives: 08 hb 5sp
205/40 federal 595's are a fat tire and fit 9.75's easily. Fender clearance will be totally different. Yokohama S drives come in 215/35/17. There is a pic of them on 9.75's on tyrestretch.com. I sent a PM to the owner (don't remember what forum) but she ran them briefly and didnt have any more pictures. I was leaning towards these before going into 8.25 bitch mode.
Edit:
http://tyrestretch.com/9.75_215_35_R17/
Google found 215/35/17
Falken fk452 $126 NLMotoring
Hankook h105 $111
Yokohama S drive $115
I'm surprised at your current clearance on only 6/6k's. to go lower and get the fitment tighter you'll probably need to go with stiffer spring rates.
Benedict is offline   Reply With Quote
Old 01-12-2013, 07:59 AM   #3
1.5
Form>Function
1.5's Avatar
I had been Googling and checking tyrestretch for a while and I see other people running 205 on this wheel but its still a hella stretch and I drive like 25 miles a day through some kinda shotty roads. I know if I went with that setup I would have tons more clearance tho.
I love s drives as a tire but those things are so damn fat their 215 prolly fits more like a 225. I've run 3kg, 6kg, and 7kg in the rear and these 6s are my favorite thus far. Idk what to do, my bitch mode is kicking in too lol
Old 01-12-2013, 04:56 PM   #4
DeathBeard
DeathBeard's Avatar
Drives: 2010 Yaris S
Have you considered slotting your top strut hole?
"In his heart a man plans his course, but the Lord determines his steps."
Proverbs 16:9
DeathBeard is offline   Reply With Quote
Old 01-12-2013, 08:08 PM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Best non-perverted one-liner question yet.
Old 01-13-2013, 08:36 AM   #6
1.5
Form>Function
1.5's Avatar
That would give me more camber adjustability but that would cause me to rub the strut housing unless I run the spacers. I'm thinking if I can just find a better tire stretch I will solve any clearing issues there. Especially since one of the only alignment shops in my area who installs camber bolts couldn't do mine properly. I don't know if I trust them to do that.
Old 01-12-2013, 07:19 PM   #7
vten
I like it when you said "bitch mode" :D
Old 01-13-2013, 09:15 PM   #8
Benedict
Drives: 08 hb 5sp
I doubt you will find a tire that is physically smaller than your 215/40 512's that will seat properly.
Federal 595 205/40's are labeled smaller but in reality are larger than what you have now. Other than the possibility of finding a 215/35 that works you're pretty much out of options. Falken 912's may be an alternative to the 512's though. So it's pretty much up to alignment and fender work to get the fitment you want.
I'm pretty confident that these will fit perfect (to my eye) with double front camber bolts, rear camber shims, a slight pull, and going another half inch to one inch lower.
Old 01-14-2013, 07:40 AM   #9
1.5
Form>Function
1.5's Avatar
Well I pulled the trigger on some 05/40s so they should be here Thursday. This will be the largest stretch I've ever tries but if people are out there dd'ing 205s on 10"s then I should be fine. I always keep a close eye on my car so I think ill be fine. But I didn't almost finish shaving down the front and pulled the fenders more.
Old 01-14-2013, 01:27 PM   #10
Benedict
Drives: 08 hb 5sp
What brand and model tire did you buy?
Remember, when stretching tires and every mm counts you can not go by tire sizing alone if you are comparing multiple brands. Tire sizing and treads wear ratings are NOT standardized industry wide. A 255/35/18 FEDERAL is wider than a 265/35/18 Falken, and a 205/40/17 FEDERAL is wider than a 215/xx/17 Falken.
Old 01-14-2013, 01:58 PM   #11
1.5
Form>Function
1.5's Avatar
Yea I'm deff aware of the tire differences I always use s drives as a prime example. I just for kicks measured the contact patch only of my 175/50 s drives and that alone measures ~ 190mm lol
I knew federales run gordo too and I've had great success with nankangs stretching but nsii are hard to get stateside you can usually only find NsI or ns20 and I hear bad things about those to stretch. I have had good experience with falken so I picked up a set of 912s and I think that is gonna work out perfectly. Should help me get lower as well which is more of a concern to me than the fender/bumper clearance. If I was fine with my current ride height I would keep the 215s.
And if I have to daily my car on some super baller stretch so be it lol
Old 01-14-2013, 10:00 PM   #12
Benedict
Drives: 08 hb 5sp
Awesome. I hope the 912's work out. I'm looking forward to seeing this lower.
FYI I just found pics on tyrestretch of 205/40/17 Achilles ATR sport on a 17x9.75 so they are an option (and only $50 each from onlinetires)
Old 01-14-2013, 11:58 PM   #13
1.5
Form>Function
1.5's Avatar
Yeah I saw that one before too and I've seen those tires a lot recently. There are quite a few cheap tires in my sizes so its good to know I've got plenty of replacement market.
Since I got new tires for my fronts I already have a replacement pair for the rears.
Old 01-24-2013, 06:40 AM   #14
1.5
Form>Function
1.5's Avatar
This is old but here is some local coverage i got. Shout out to C12Productions and I Love Driving Slow
http://www.facebook.com/photo.php?fb...type=1&theater
For those too lazy to click:
Old 01-24-2013, 07:16 AM   #15
SilverSquash!
Stage ...Base
SilverSquash!'s Avatar
Drives: Toyota Yaris LB '07
Over sick stance! Looking sweet and grounded
SilverSquash! is offline   Reply With Quote
Old 01-24-2013, 07:52 PM   #16
Benedict
Drives: 08 hb 5sp
Definitely too much gap for me. Needs to be lower or upsize the wheels. That's why I'm looking forward to the new 17's.
Can you post a close up of your front Toyota badge?
Old 01-28-2013, 10:32 AM   #17
1.5
Form>Function
1.5's Avatar
yeah I lowered a lil more after those pics and then I was at my lowest, dragging frame all over town. Now my 17s gave me a ton more clearance and filled my wheel wells out a ton so I am still working on them so I can go a little lower but here is an update til then
rear camber done/New tires on the front/lowered slightly/
Name:  front ground.jpg
Name:  rear ground neg.jpg
Name:  one wheel neg.jpg
Still needed: a little more cutting around the fender/headlight/~ 2" section on each fender of pulling needed in addition to what I have/SLAM IT!!!
Old 01-28-2013, 06:48 PM   #18
HANZO_187
#CarFiend-HANZO188
Drives: 2011 Toyota Vios
The car is lookin better by the day bro.
HANZO_187 is offline   Reply With Quote
Build thread! '08 Yaris Hatch nimuntak Photo-Video-Media Gallery 105 01-28-2014 02:28 PM
PETERPOOP's Turbo Build Thread. PETERPOOP Forced Induction Forum 114 02-08-2011 10:21 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
