Old 10-08-2012, 08:40 AM   #1
toyoti
Drives: 2008 yaris
YARIS SPEEDO BACKLIGHT
Yes I have a multi tester. It´s a bear to use under the dash!! I´ll be downloading the schematic later on todau. I appreciate your help.
toyoti is offline   Reply With Quote
Old 10-08-2012, 08:52 AM   #2
Rather than checking voltages on the dimmer rheostat, start with checking them at the connectors on the cluster.
Specifically, on the right side connector, check the black wire on the top right for 12 V (the brown on the bottom left is ground).
Also check the blue next to the black for 12 V as well.
Also, measure the voltage on the grey and yellow wires with the headlight switch both on and off. Those two wires are the input to the cluster from the dimmer rheostat.
Speedometer Accuracy? YarisPete DIY / Maintenance / Service 37 11-29-2013 02:00 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 09:00 PM
OEM Speedometer with tachomter Deshi Basara DIY / Maintenance / Service 6 08-21-2012 10:11 PM
speedometer walt101786 Cosmetic Modifications (Exterior/Interior) 0 10-09-2010 09:03 PM
No speedometer or tachometer lights during day cdavidhess DIY / Maintenance / Service 20 06-30-2009 10:38 AM
