#1 | |
Specifically, on the right side connector, check the black wire on the top right for 12 V (the brown on the bottom left is ground). Also check the blue next to the black for 12 V as well. Also, measure the voltage on the grey and yellow wires with the headlight switch both on and off. Those two wires are the input to the cluster from the dimmer rheostat.
| Speedometer Accuracy? | YarisPete | DIY / Maintenance / Service | 37 | 11-29-2013 02:00 PM |
| Speedometer Calibration / DeMetrification | CTScott | DIY / Maintenance / Service | 17 | 10-06-2012 09:00 PM |
| OEM Speedometer with tachomter | Deshi Basara | DIY / Maintenance / Service | 6 | 08-21-2012 10:11 PM |
| speedometer | walt101786 | Cosmetic Modifications (Exterior/Interior) | 0 | 10-09-2010 09:03 PM |
| No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 10:38 AM |
