Old 10-09-2012, 12:16 AM   #1
CPALK719
CPALK719's Avatar
Drives: 2012 toyota yaris
Originally Posted by Absolutely Red 12 View Post
The lamps are fine as long as they are DOT stamped.
On my 2012 L, I did not need the included harness, nor the relay or switch.
The car was prewired, I installed the lamps, and covers, then wired 2 wires of a 4 wire switch to jump the purple and green wires of the stalk connector at the bottom of the picture. The other 2 wires were tied to the shifter illumination wires.
interesting. and you think all these ebay kits are DOT approved?? lol i would think not. i could be wrong. so did you have to remove the front bumper or were you able to get around doing that?
2012 yaris L model
2014 wrangler unlimited sport
CPALK719 is offline   Reply With Quote
Old 10-09-2012, 12:41 AM   #2
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
I didn't say they were all DOT. I got lucky, bought mine from Amazon, (Vendor: Kramer America)
Pulled the pins on the upper bumper, pulled out both sides from the fender.
Bumper leaned forward, and I reached down to install the lights.
Found the fog plugs taped to a harness, right next to where the fogs are.
Did not remove anything from the bottom of the bumper.
The only reason I pulled the bumper was that I replaced the headlight bulbs with Philips CrystalVision Ultra 9003 Headlight bulbs, to match the same H11 I replaced in the fogs.
These fogs only come with Osram 3000K bulbs.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
Old 10-23-2012, 04:58 AM   #3
odg495
odg495's Avatar
Drives: Yaris & Corolla
Just for people like myself, the kind of inept people that burn water and break anything they touch, can you just tell us in more detail how you pulled out both sides from the fender?
Is there a trick to it, or do you simply pull it out as you said? I'm OK with the pins on the upper bumper, so I'm halfway there!
Cheers in advance!
odg495 is offline   Reply With Quote
Old 10-23-2012, 10:48 AM   #4
Absolutely Red 12
Asshole
Cheers in advance!
Now pull the bumper at the fender liners, there are retaining nubs where it meets the fender, there are also retaining nubs under both head lights. A decent tug will remove it, and lean forward, for lights you do not need to remove lower bolts.
It will remind you of a hood (bonnet) being opened on a Mack truck!!
Old 10-24-2012, 04:49 PM   #5
odg495
odg495's Avatar
Great, thanks again ... I'll give that a go this weekend.
Old 11-04-2012, 06:42 PM   #6
odg495
odg495's Avatar
Well, we now have undisputed proof that anyone can fit fog lights to a Yaris!
I'll let an auto electrician friend do the final wiring inside, but otherwise, they're ready to go!
Thanks to everyone for their advice and instructions, too!
Old 11-19-2012, 02:08 AM   #7
odg495
odg495's Avatar
Let there be light! Fogs all wired up, plus we threw on some driving lights while we were at it ...
FEELER: Possible New HID Vendor hydrohopper Cosmetic Modifications (Exterior/Interior) 17 06-11-2010 01:05 AM
WTB: Gauge Cluster w/tach for HB cdydjded Willing to Buy by private party 12 06-09-2010 03:49 PM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Toyota Yaris 5 Doors Body Kits k3nn4 Australia 23 05-08-2009 10:28 PM
2009 foglight kits? songa Cosmetic Modifications (Exterior/Interior) 3 12-10-2008 11:58 AM
