Old 11-26-2009, 01:51 AM   #37
YarisSedan
Drives: 08 Yaris Sedan
Okay i found the pics so everything is relinked and back up now.
Old 04-15-2010, 05:11 PM   #38
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Hey, Thanks for the write up. Just did it yesterday and you're right, the braking is entirely better.
Old 08-05-2010, 03:34 PM   #39
skoolafish
Drives: 2008 Polar White Yaris Sedan
i just had a 27 point inspection or something at a toyota dealer
they told me my rear brakes were out of alignment, and explained it like my brakes were not expanding enough to grab the sides of a bowl or something...
is this what i need to do to fix that?
skoolafish is offline   Reply With Quote
Old 02-19-2011, 05:27 PM   #40
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
HELP HELP HELP. in middle of doing this, only have 30 mins til i gotta be somewhere. i CAN NOT get off the brake drum. i see im slightly bending the backing plate when i try the screw driver method. any help??!!?
Club SHIFT
Old 02-20-2011, 06:22 AM   #41
rningonfumes
^I guess it's too late but... 1. Parking brakes off. 2. Whack it with hammer or mallet a few times. or.. 3. do the appropriate bolt size into the hole to force it off that way.
I just whack it with a hammer.
Old 02-20-2011, 09:24 PM   #42
bankrobber
Drives: 2007 Yaris Hatchback
Best way is using the bolts to ease it off 10 MM if I remember correct. I bent the crap out of my backing plate before trying the bolts.
bankrobber is offline   Reply With Quote
Old 02-21-2011, 06:01 PM   #43
TickleTimeTim
Free Mustache Rides
thanks for clarifying the size of the bolts, i had a box of screws (including wood screws-i got desperate) but didn't have the right size and gave up. i tried to go through the rubber plug that everyone suggested not to go through (once again, desperate) but i had no idea what i was doing. guess ill go to hardware store, pick up 2 10mm bolts and try again next weekend. thank you
Club SHIFT
Old 02-22-2011, 08:28 AM   #44
bronsin
bronsin's Avatar
arent these brakes self adjusting? Dont they adjust when you back up? Or doesnt that setup work after a while?
Old 02-22-2011, 11:42 AM   #45
rningonfumes
Yes, they adjust as you back up. The adjustment allows you to apply the same amount of distance in the foot. The problem lies in the the cable/hand brake. I don't know the reason for this but you still have to adjust it every-so often in order to tighten that up. It is important to note that you should adjust at the brakes first, then see about tightening at the base of the hand brake.
Old 02-22-2011, 05:27 PM   #46
746watts
Drives: 2014 yaris hybrid
Thanks YarisSedan, I am soon going to be replacing my shoes which have 135,000kms on them. Knowledge sharing is appreciated.
Okay, did my oil & filter change this evening and checked the drums while I was at it........... new shoes have 4.6mm of braking material and the shoes after 135,000kms have 3.6mm of brake material left. So I'll leave them in for another 1mm of wear I reckon.
746watts is offline   Reply With Quote
Old 04-11-2012, 12:41 PM   #47
xhifer
Drives: none
Sorry for the bump. But OP can you please relink the pics? Thanks
xhifer is offline   Reply With Quote
Old 09-19-2012, 05:05 PM   #48
NEexpat
Drives: 2009, auto, 4dr LB
Ok, I am not seeing these pics.
Is it just me or are they gone? If they are gone from this thread does anybody have them?
Thanks.
NEexpat is offline   Reply With Quote
Old 10-13-2012, 12:46 AM   #49
YarisSedan
Sorry guys the account I used for Web hosting closed so some pictures are lost I have to adjust my rear brakes again soon so ill try to put some new pics up and put them on photo bucket with a link
Old 10-13-2012, 09:50 AM   #50
NEexpat
^Thanks.
Been wanting to do this.
cheers
Old 10-15-2012, 04:36 PM   #51
nookandcrannycar
Well there were pictures up unfortunately they are lost thats why im hoping someone might have viewed it and still ahve images in thier cache before i changed server hosts. Otherwise i might have to redo the diy and take new pictures all over again.
I had both on my car done about 23k miles ago (so I probably won't need to again for quite a while) and I paid only a little bit less than Jamal1984 did. The pictures will help more than a few people whenever you are able to get pics to display and all will appreciate your gesture.
Old 01-30-2013, 05:09 PM   #52
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Yes,if someone could repost the pics, that would be a great help.So, you adjust the drum first,then adjust the parking brake?.Now the adjustment for the parking brake lever.....is this a different procedure? or is the lever adjusted when the drum brakes are adjusted/taken-up?.
frog13 is offline   Reply With Quote
Old 02-02-2013, 06:44 PM   #53
Yarflana
Drives: 2008 Base Model
At the end of all this, sounds better to service the entire rear brake assembly at one time vs. cleaning and messing with all the dust to just adjust the parking brake. I know it is rather comforting to have it adjusted where you only have to pull a couple clicks, but it doesn't hurt to have to pull it a few more clicks until you can get around to an entire "drum rotating, shoe changing, assembly cleaning" service.
Honestly, I wouldn't worry about cleaning it much if all I was doing was adjusting the parking brake. Likely not the best way to go, but cannot make it any worse than before getting in there.
Overall, however, thanks for the DIY. I know it takes a lot of effort to take pics and upload all those instructions.
Yarflana is offline   Reply With Quote
Old 02-02-2013, 08:27 PM   #54
nookandcrannycar
I didn't like the sound coming from that area. The sound motivated me to have it checked. The local shop I went to (not a dealer) cleaned out all the dust and serviced the cable (I thought the sound might be signaling something more extensive). When I left, the cable was as tight as when the car was new and the sound that had motivated me to take the car in was gone. The miniscule cost was worth it to me. My brakes continue to work as new, had only 20% wear at approximately 208,000 miles, and I've never done anything else to the brakes (front or rear). Might not be what works for others, but has worked for me. Just my 2 cents .
Rotated tires and adjusted rear brakes today PICS auxmike DIY / Maintenance / Service 11 11-14-2008 09:24 AM
Yaris/Echo Rear Brake Question pdarnell DIY / Maintenance / Service 2 08-21-2007 02:15 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 09:47 AM
Rear brake proportioning valve??? PetersRedYaris DIY / Maintenance / Service 16 03-26-2007 12:10 AM
