Old 10-23-2012, 12:40 PM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Am I the only one not seeing a problem with those temps??? Engine overheats don't normally happen till your well past the 240 range and 195 is the thermostat temp for most engines out there hell my Mustang would regularly see 220+ on track and it wasn't even close to overheating.
You actually want it to run a little bit hot as you'll get better fuel economy and a longer life from the piston rings and better emissions in most cases and even slightly more power.
Also its a waste of money to change your oil at 3k since the recommended interval is 6k. These engines don't have much blowby so the oil doesn't get contaminated as quickly which means it has a longer service life.
Also temp needle in most cars is just slightly better than a dummy light as it won't move unless the temp jumps way above 240 which its almost to late anyway. If you've ever driven a car with a real temp gauge it moves all over the place driving around it can range from anywhere between 160-220 but most OEMS don't want to get service calls for non issues so they limit movement on the gauge to keep people from thinking there's a problem when in reality theres nothing wrong.
Old 10-23-2012, 01:26 PM   #2
The idiot light doesn't come on on the Yaris until the temp hits 242 F, and the service manual considers temps under 221 F to be normal.
I find that once my car warms up that the coolant temp has very little fluctuation. On a 100 F day it stays in the 185 F to 189 F range and will bump up to a max of 195 F when sitting at a light. The OP is probably cruising through the desert in 110 F+ temps, so the temps he is seeing are probably well within reason.
extra speakers ? yariSB86 In Car Entertainment + Electronics (audio / video / alarm) 26 06-25-2012 11:29 AM
Anyone have an extra front badge? schleppy New England 4 08-05-2010 04:41 PM
Extra Output signal from OEM deck charleschia1986 In Car Entertainment + Electronics (audio / video / alarm) 5 09-28-2009 12:28 PM
not yaris related, but looking for a cooling system guru turboyaris Performance Modifications 17 04-13-2009 09:29 PM
Has anyone fashioned brake cooling ducts for the LB? LtNoogie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-11-2009 12:45 PM
