![]() Drives: yaris s hatchback 2008 Join Date: Oct 2012
simple question
Hello! Im new in the forum, my mother in law yaris went in a light rear accident recently. Now the passenger airbag light always is in off. No matter somebody seated or buckle up. i read this thread and i understood what to do. But i have a problem. I cant download the service manual from the link provided. Only i need to know what pin is TC and what pin is CG physical in the obd 2 conector to make the jumper. Thanks for the help!
#2 | |
Hello scott! i went to post#2 and i found only a link. When i hit this link i cant find nothing about how to find TC and CG pins in the obd 2 conector. I apreciated if you can tell me directly to me how to find those pins in the obd conector. I checked the obd conector in the car and i dont found any pin number or letters in the conector. Thanks
#4 | |
Ok! now is working! i have the diagram! tomorow morning im going to make the procedure. i will let you know the results! Thanks for your help.
Found problem!
Hello Scott! I followed your instructions and works perfect. I got code 32. This code was pointed to the passenger seat. Troubleshooted with another passenger yaris seat (we have 2 yaris car in my family) and found the "computer occupant detection" inop. i have luck to have 2 yaris car in my family and help me to troubleshooted more fast. Is incredible that only a light rear accident (broken rear bumber and hatchback door vent only) went broken this computer. Around 300.00 usd new in the toyota and around 50.00 dollars used and i need to fix the body also. Well i choosed the used computer option. Thanks for your help see you soon!
#7 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Help! Airbag light issue | Astroman | DIY / Maintenance / Service | 24 | 05-18-2019 12:35 PM |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| passenger airbag light problem (NOT stuck on) | ersheff | General Yaris / Vitz Discussion | 3 | 10-12-2010 08:20 AM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
