Old 10-28-2012, 01:42 PM   #1
bikeman111
Drives: yris sedan
my experience with my fiancee`s 08 yaris 5speed sedan.If the car is allowed to idle for at minimum of one minute it always starts fine,if you shut it off without letting it idle 95% of the time it will crank,cough and die like its not getting fuel.I pop the hood when this happens and pull the fuel pump fuse and refit it a couple times then it starts and runs perfectly.The faster its shutoff the longer it takes to get it running again..possible the time I spend playing with fuses is coincidental??
The fuse panel under hood has been replaced and seems worse since
bikeman111 is offline   Reply With Quote
