Old 10-29-2012, 06:34 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
OK! got it to work with 10A! It's showing me good result in reverse (4-5amps). In Park it's showing 0.05amps. I just put a new fuse in, no problems when i put in reverse, so far so good. But I have disconnected my reverse camera(signal wire) and all the connections from seat heater. It seems like the signal wire from reverse camera might be the culprit, since the extension I made, the wire is thinner than the original wire, i think that might be the reason. Like the original wire might be a 16AWG, but i put a 24AWG wire for extension, I think that's why. But It hasn't got any problems for the past few months. I will definitely put an eye on it and in the future I will start hooking back up the heated seats, and then finally the reverse camera(After I fixed the wiring). I think I should be good, at least now I know how to test current without a fuse.
Thanks a lot, really appreciate your time! <3
